Nous sommes actuellement le Lun 21 Juil 2025, 20:06
Publier un nouveau sujet Répondre au sujet  [ 1374 messages ]  Aller vers la page Précédent  1 ... 66, 67, 68, 69, 70, 71, 72 ... 92  Suivant
 Sujet du message : Re: Umul & ITB...
Message Publié : Ven 19 Fév 2010, 17:00
Message(s) : 5119
Synchro des papillons faite, elle tourne bien mieux ! :oui:
MX5 Strato blue mica
Message Publié : Sam 20 Fév 2010, 14:35
Message(s) : 5119
Vidange faite, et sonde de t° d'eau réparée (c'était bien le fil rayé rouge et bleu, qu'on avait du arracher à sa connectique lors du montage des itb).
ça devient bon...!
Message Publié : Dim 21 Fév 2010, 19:09
Message(s) : 5119
Bon, pour info, il y a un mois, après quelques échanges de mails, j'ai reçu des tables pour ITB de chez DIY Autotune :
Lydéric,
We were hoping we'd have a map very close to your specific setup, but it looks like I lost it when I had a problem with my laptop way back when. (Disabled UAC on Vista and it deleted all files I had in a subdirectory of the program files directory...beware)
Here's the maps from Roger Futrell's ITB Zetec car, which will at least be shaped close to right for another 4cyl ITB car, but they are NOT tuned for a Miata. ITB cars fuel maps particularly look VERY different from single throttle body maps. And though this has the right shape, it was for a pretty different motor.
There's really no getting around putting this car on a dyno and tuning it out right, but these maps may help smooth out the process a bit as the shape is right for an Alpha-N based ITB car.
It's very likely that if the ECU is setup for Alpha-N and these tables are loaded, then the fuel table (whole table) is scaled up to where the car idles where it should (13.5:1 ish), then it 'may' run ok everywhere to put it around, but it will need to be tuned and running it without being properly tuned could have damaging results. I hope this helps you out and gets your tune at least pointed in the right direction!
Thanks,
Jerry Hoffmann
DIYAutoTune.com
Donc j'avais prévu de les rentrer dans le MSpnp pour essayer un peu (en attendant ma carto de ce 6 mars prochain en Angleterre), histoire de faire joujou...
Message Publié : Sam 27 Fév 2010, 00:41
Message(s) : 5119
Alors, la table Spark ça a l'air OK.
Spark table
12.0 14.0 16.0 23.5 30.0 35.0 36.0 38.5 38.9 39.0 38.9 39.0
12.0 14.0 16.0 23.5 29.0 34.5 35.5 38.0 38.4 38.8 39.1 39.6
12.0 15.0 16.0 22.5 28.0 34.0 35.0 37.5 37.8 38.1 38.4 38.7
12.0 15.0 17.0 21.5 28.0 33.0 34.5 37.0 37.3 37.5 37.8 38.0
12.0 15.0 17.5 21.0 27.0 32.0 34.0 37.0 37.7 37.4 37.6 37.8
12.0 15.0 16.5 20.0 26.0 31.5 33.5 36.5 36.7 36.8 37.0 37.1
12.0 15.0 16.3 18.0 26.0 30.0 32.0 34.0 34.2 34.3 34.4 34.5
13.0 15.0 16.0 17.5 25.0 28.5 28.5 31.0 31.2 31.3 31.4 31.7
13.0 15.0 15.5 17.0 23.5 25.5 27.0 28.0 28.1 28.2 28.3 28.5
12.0 14.0 15.0 16.5 21.0 24.0 25.5 28.0 28.0 28.1 28.2 28.3
12.0 14.0 15.0 16.0 21.0 23.0 25.0 26.0 27.0 27.5 27.9 28.2
11.0 14.0 15.0 16.0 20.0 22.0 24.5 26.0 27.0 27.4 27.8 28.1
(nb : il me supprime les décimales automatiquement)
Par contre la table Fuel, j'ai pas 144 cases, mais 256, soit 16 lignes pour 16 colonnes à rentrer dans une table de 12 x 12
Fuel table
100,0 -- 33.0 32.0 32.0 29.0 26.0 27.0 27.0 27.0 27.0 27.0 25.0 24.0 23.0 22.0 21.0 20.0
91,0 -- 34.0 33.0 35.0 33.0 33.0 30.0 30.0 29.0 32.0 32.0 32.0 31.0 30.0 29.0 28.0 27.0
80,0 -- 33.0 34.0 37.0 39.0 37.0 34.0 33.0 33.0 33.0 33.0 33.0 32.0 31.0 30.0 29.0 28.0
68,0 -- 44.0 47.0 41.0 40.0 35.0 31.0 33.0 34.0 33.0 33.0 32.0 31.0 30.0 29.0 28.0 27.0
57,0 -- 56.0 54.0 46.0 43.0 39.0 36.0 34.0 33.0 35.0 35.0 34.0 31.0 29.0 28.0 27.0 26.0
47,0 -- 64.0 64.0 56.0 52.0 47.0 40.0 38.0 37.0 37.0 36.0 37.0 34.0 32.0 30.0 28.0 26.0
37,0 -- 70.0 71.0 61.0 55.0 51.0 44.0 40.0 39.0 40.0 38.0 40.0 37.0 32.0 30.0 28.0 26.0
28,0 -- 78.0 87.0 82.0 70.0 63.0 55.0 49.0 46.0 46.0 42.0 41.0 38.0 36.0 34.0 32.0 30.0
23,0 -- 86.0 92.0 90.0 83.0 78.0 69.0 59.0 53.0 52.0 52.0 51.0 48.0 46.0 44.0 42.0 40.0
18,0 -- 87.0 91.0 89.0 91.0 92.0 87.0 80.0 76.0 73.0 69.0 66.0 63.0 62.0 61.0 60.0 59.0
15,0 -- 88.0 90.0 90.0 95.0 100.0 101.0 96.0 91.0 88.0 80.0 79.0 76.0 73.0 71.0 69.0 67.0
12,0 -- 88.0 92.0 92.0 93.0 99.0 100.0 102.0 102.0 100.0 98.0 97.0 89.0 86.0 83.0 81.0 78.0
9,0 -- 88.0 92.0 94.0 96.0 98.0 99.0 100.0 98.0 95.0 95.0 97.0 92.0 83.0 81.0 77.0 75.0
6,0 -- 89.0 92.0 93.0 96.0 98.0 99.0 100.0 99.0 99.0 99.0 101.0 101.0 95.0 93.0 87.0 85.0
3,0 -- 90.0 93.0 94.0 97.0 99.0 99.0 100.0 100.0 100.0 100.0 101.0 102.0 101.0 102.0 99.0 97.0
0,0 -- 92.0 94.0 95.0 97.0 98.0 98.0 99.0 100.0 101.0 101.0 102.0 105.0 103.0 104.0 102.0 100.0
-----1000 1400 1800 2200 2600 3000 3400 3800 4200 4600 5000 5400 5800 6200 6600 7000
J'ai loupé un épisode ? :aie:
Ou cette seconde table ne correspond pas au Megasquirt ?
Je pars à la chasse aux infos....
Message Publié : Sam 27 Fév 2010, 09:17
Message(s) : 11109
Il n'y a pas une histoire de megasquirt V2 ou V3 la premiere gerant une table 12*12 et l'autre une table 16*16 avec un proc plus performant ?
Il t'a peut etre envoyé une table pour megasquirt V3 ?
Je dis ça c'est peut etre des conneries, mais bon comme je me suis un peu renseigné il y a quelque temps :idea: je crois me souvenir d'un truc comme ça...
Message Publié : Sam 27 Fév 2010, 09:36
Message(s) : 1829
Umul,
C'est une carto essence pour une msq V2. C'est pas grave, il suffit de recaler les valeurs avec tes régimes attendus.
Il te la faut pour quand cette fuel map? Je comparerais aussi ta carto allumage. Les avances m'ont l'air un poil énervées...
Romano.
Message Publié : Sam 27 Fév 2010, 10:37
Message(s) : 1829
Fuel table
Fait gaffe aux valeurs données pour ta carto essence: elles sont l'air inversées par rapport à ta charge (colonne de gauche).¨Là plus tu charges, plus tu appauvris...
Message Publié : Sam 27 Fév 2010, 12:32
Message(s) : 5119
Ah d'accord...
Ce sont en effet les tables que j'ai eues, et si c'est risqué, je ne préfère courir aucun risque, d'autant plus que dans une semaine elle passe au banc pour la map complète.
En attendant j'vais pouvoir quand même voir un peu comment ça fonctionne exactement ! :)
Merci !
Message Publié : Dim 28 Fév 2010, 21:36
Message(s) : 1829
Umul a écrit :
Ah d'accord...
Merci !
je t'ai mis ça en mp... Le .vex bien sûr.
Bien sûr tu vérifies avec ta WB!!
R.
Message Publié : Dim 28 Fév 2010, 21:53
Message(s) : 5119
Message Publié : Mar 2 Mars 2010, 23:44
Message(s) : 5119
Bon, après avoir passé bientôt 2h sur msn avec ce fada Megasquirtien qu'est Romano, mes tables sont prêtes à être rentrées.
Si mon PC le veut bien, c'est pour demain soir, et test.
MERCI !! :jap:
Message Publié : Mer 3 Mars 2010, 23:43
Message(s) : 1829
MERCI !! :jap:
alors ca wiiiin ces ITB?
R.
Message Publié : Jeu 4 Mars 2010, 00:29
Message(s) : 5119
Impossible de relier le PC au MS........ le port n'est pas reconnu.
RS232 connecté au port com11, même port dans les menus Megatune, et nada... :tantpis:
Message Publié : Jeu 4 Mars 2010, 14:12
Message(s) : 1829
c'est aussi pour ça que je ne suis plus sous megatune...
Message Publié : Jeu 4 Mars 2010, 14:17
Message(s) : 5119
Sous XP ça fonctionne très bien.
Evidemment, moi Vista... :aie: source réelle de problèmes ce vista ?
Et donc tu n'utilise pas Megatune, mais quoi ? :D
Publier un nouveau sujet   [ 1374 messages ]  Aller vers la page Précédent  1 ... 66, 67, 68, 69, 70, 71, 72 ... 92  Suivant Répondre au sujet
