Nous sommes actuellement le Ven 18 Juil 2025, 02:40
 Sujet du message : voiture de piste a vendre UK
Message Publié : Mer 27 Août 2014, 19:46
Message(s) : 1622
Prépa de fou!
http://www.mx5nutz.com/forum/index.php? ... 152587&hl=
"Facile. Une deuche."
Message Publié : Mer 27 Août 2014, 20:05
Message(s) : 7687
un petit import serait sympa pour ceux non inscrit donc sans acces! :non:
Message Publié : Mer 27 Août 2014, 20:33
Celle là! :bave:
7500£
c'est cadeau vu les pièces dessus (4pap Jenvey, mahura à donf, portière fibre De Marc et plein d'autre trucs....)
ste, on 27 Aug 2014 - 12:26 PM, said:
1994 Mk1 MX5 (NA) Track / Fast Road Car.
Well sorted NA track car. Built to a very high standard and proven to be incredibly reliable and quick on track. Drive it to a circuit, lap all day and drive it home. Always maintained meticulously - with a full folder of history and receipts to back up all maintenance and work that's been carried out.
CIrca 190bhp on naturally-aspirated engine and 875kg so around 220bhp/tonne with amazing throttle response.
Body
- Full respray in Renault Storm Grey (KNQ)
- 'Rustfree' shell, with sills replaced by MX5Restorer.
- Lightened - all unnecessary brackets removed. Interior seam sealer removed.
- New Genuine Mazda replacement wings
- Honeybourne Mouldings lightweight hardtop with plastic rear screen
- Autokonexion V2 ducktail bootlid fitted with Aerocatches
- Early lightweight doors, pre-impact bars with windy windows. Interior metal skin trimmed to reduce weight
- Garage Vary lightweight GRP front bumper without marker mouldings
- Rear bumper with aero cut and marker mouldings filled
- JDM finish panel with lock hole removed and filled.
- SPA carbon mirrors
- Moss TSIs (standard sidelights also included)
- Garage Vary PU lip
- Bonnet catch removed and bonnet mounted on Aerocatches
- Plastics4performance Lexan Margard windows
- Bespoke, lightweight Ardler Automotive wiring loom including engine bay wire tuck
Chassis
HSD coilovers
Ultra Racing uprated adjustable anti-roll (sway) bars
De-powered rack
IL Motorsport Uprated Engine Mounts
WIM alignment to custom specs
Engine & Drivetrain
1Image
- 1999 BP head from a JDM NB RS - skimmed, ported and flowed by Gugliemi Motorsport. Fitted with Supertech uprated valve springs, Supertech titanium retainers and supertech valve stem oil seals.
- Maruha 272 / 264 cams
- Maruha shim-under bucket lifters
- 2002 NB2 VVT 'high compression' bottom end, rebuilt with new genuine rings and new genuine Mazda gaskets
- Jenvey TB45 Individual Throttle Bodies on Jenvey NB manifold, Jenvey throttle linkage, vacuum parts, etc
- Jenvey custom offset backplate
- Reverie Zolder carbon airbox with ITG internal filter
- Bosch injectors
- Fuel pressure regulator for ITBs
- MS2 Megasquirt with custom Ardler Automotive loom including wideband Lambda
- 8mm silicone HT leads (red)
- Fidanza vernier cam gears
- GarageStar Lightweight Waterpump and Alternator Pulleys
- Chopped NA cam cover
- Maruha carbon cam gear cover
- Racing Beat 4-1 manifold
- QP Decat pipe
- RS Factory Stage N-Zero 2 Exhaust
- 52mm alloy radiator
- Maruha radiator cap
- Mocal 13row thermostat controlled oil cooler
- Mocal vented oil catch tank
- All hoses changed to silicone - black
- Coolant re-route
- F1 Stage 3 uprated paddle clutch and F1 lightweight 4.5kg flywheel
- TorSen LSD
- IL Motorsport uprated/harder engine mounts
Wheels and Tyres
- 949 Racing 6UL - 15x8j Et36 (satin black) with new 195/50/15 Avon ZZRs.
- 949 Racing open-ended wheelnuts
- 949 Racing aluminium spigot rings
- 3mm Hubcentric spacers
Brakes
- 1.8 hubs with extended ARP wheelstuds
- 1.8 brake calipers
- OEM Genuine Mazda discs
- Carbon Lorraine RC6 pads
- HEL Stainless brake lines and distribution block
- HEL single piece braided clutch hose
- ATE Superblue fluid
- Jass brake master cylinder stopper
- Factory compensator removed
- NB Brake Servo
- NB Brake Master Cylinder
- Tilton brake bias valve
Interior
- Stripped out of factory trim, carpets etc.
- All unnecessary brackets, metalwork and seam sealer removed
- Lightweight cut-down dash
- Custom carbon dash panel
- Bespoke Ardler Automotive interior loom - ECU (MS2) moved to transmission tunnel
- Electrical Kill switch
- HardDog M1 Hard Core rollbar with harness bar and custom X-Brace
- TRL Doorbars
- Recaro SPG seats fitted to MSA spec on side mounts (factory humps removed).
- Shroth 6 points harnesses (Porsche 996 GT3 RS)
- Suede 330mm Momo 78 steering wheel
- 'Driftworks' removable steering wheel boss
- White nylon gearknob
- Jass lightweight hardtop fitting kit
- Lightweight lucas battery
- Rallye Design Lightweight alloy Passenger Footrest
- Lightweight Polyvinyl Doorcards
- Wind-up windows
- Porsche RS door pulls (red)
Miscellaneous
- PAS removed
- AC removed
- Jaas stainless front tow hook
- Rennenmetal rear tow hook
- Hidden lightweight washer fluid bag and pump
- Crystal Autopal Headlights with Osram Nightbreaker Ultimates
Huge service history file with all receipts.
12 months tax
12 months MOT
£7.5k
PM me on here
Email: me@stenelson.co.uk
Phone: 07968 444 017
Unfortunately it's worth more in parts. I'd rather not break it as it's been a labour of love and a proven package that someone can jump in and enjoy. I realise that unfortunately it'll probably end up getting sold as parts though, but thought I'd offer it as a whole package first. Price is negotiable depending on parts included. I can remove parts not needed and sell it for less. Alternatively, I can include some or all of the following at a negotiated additional price:
- V8 Roadsters tubular front subframe
- SuperMiata (949 Racing) competition engine mounts (70D Durometer)
- Full blasted and coated set of rear subframe, all wishbones etc
- IL Motorsport uprated bush kit (full car set)
- 949 Racing poly diff mounts
- Honda Civic Radiator (60mm core)
- 949 Racing 6UL - 15x8j Et36 (silver polished) with Michelin 19/57-15 S9C slicks
Message Publié : Mer 27 Août 2014, 20:36
Message(s) : 7687
Panda2 est a vendre? :o .... clair que c'est une super proposition à ce prix :)
Message Publié : Mer 27 Août 2014, 20:53
Message(s) : 6847
'tain, c'est pas à Toulouse qu'il fallait que je me fasse muter.
mableue
mon YouTube
Message Publié : Mer 27 Août 2014, 21:00
Message(s) : 173
9450 euros... une pitié.. non seulement bien pensée, mais montée très proprement.. wouw
Message Publié : Mer 27 Août 2014, 21:54
Message(s) : 2311
j'aimerais bien savoir pour combien y'en a au total, rien qu'en pièces ! 10 000 ?
comme il dis, en pièce il en tirerais facilement un meilleur prix !
Message Publié : Jeu 28 Août 2014, 16:01
Message(s) : 4436
Belle prepa effectivement !
Le prix des pièces plus le prix du transport pour les pièces volumineuses ... :?
M
MIATA 1.8 R
Message Publié : Jeu 28 Août 2014, 17:03
Vu le prix de ma restauration il y en a pour beaucoup plus de 10 000€
Message Publié : Jeu 28 Août 2014, 17:48
Message(s) : 3869
elle est magnifique :oui:
Message Publié : Ven 29 Août 2014, 11:50
Message(s) : 2106
:love2:
Message Publié : Ven 29 Août 2014, 12:13
Message(s) : 12205
Wahouu elle est super belle, elle est légère, puissante et atmo :bave: :bave:
Et en plus elle est à vendre :etonne:
Message Publié : Ven 29 Août 2014, 12:35
Yacco, tu ne devrais pas regarder des annonces comme ça :ttt:
Message Publié : Ven 29 Août 2014, 13:44
Message(s) : 12205
Nan plus de capote, des baquets, c'est pas le genre de voiture qui m'intéresse :D
Plus sérieusement ça a malheureusement l'air d'être une Eunos avec son porte plaque AR, en ayant survolé l'annonce je n'ai pas lu de UK specs ou Eunos mentionné...
Par contre ce gris clair avec un p'tit rond sur la porte, c'est magnifique !
Message Publié : Ven 29 Août 2014, 15:32
Message(s) : 7687
c'est bien une JAP/JAP :D :
http://clubroadster.net/vb_forum/89-roa ... anda2.html
